A Question to 550i owners
I bought 2006 550i in August this year with 4,800 miles on it. It is a wonderful vehicle except two problems. In the morning when I start the car the engine shakes and rocks for a while. It goes away after a while. If the AC is on, it stays. The second problem is the steering wheel has a vibration and does not go away. I don't like this 'message' like vibration. The dealer checked everything and says that it is a normal for V8 engine. My question to 550i owners is - is this really normal? Thanks in advance.
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
Is the shaking and rocking you describe only happen at certain RPMs? If yes, at what RPM does it happen? At what outside temperatures?
For the steering wheel issue, does it happen all of the time or only when braking?
My Ride: G30 M550i
Model Year: 2018
It sounds like the engine has too low of an idle speed. What does the tachometer indicate when the engine is idling (and rocking?)
As far a the steering wheel vibration, it sounds like one of the front wheels is not balanced or there's a bad tire...
Originally Posted by pennetta' post='495561' date='Nov 17 2007, 09:59 AM
The V8's are rougher than the I6's, but it should not make your steering wheel shake. Has the car been modified? Are the original tires still on?
The dealer has tried to reprogram the car twice with new software and it has not solved the issues I am having. Do you think it could be the rockers inside the engine?
My Ride: G30 M550i
Model Year: 2018
Now I understand. Clearly, this is not something normal. If the dealer insists that it's normal, have him show you how another V8 on the lot does it. If you don't get anywhere with that approach, find another dealer!
As far as what could be wrong, it could be a million things, I guess. If the engine runs well at speed, it might just be a faulty electronics module -- maybe one that controls VANOS or something. I don't know what else to say except that it should be fixable under warranty...
if they had to raise the idle to 1000rpm in hopes of fixing the problem, id tell them that they dont know what they are doing. The normal idle is around 500rpm, and no car should have its idle raised 100% to try and fix an engine issue. mine is only rough upon the first morning startup, in 30 seconds, it smooths out
Rudy is correct in that it could be anything and since you did not have the car since new, you don't know everyting that its been through. Could be a motor mount of the car was in an accident, could be a defective or clogged fuel filter, etc. Ask the dealer to get the regional tech involved, BMW will do a PUMA case that pulls in factory resources.
My Ride: G30 M550i
Model Year: 2018
Good luck getting things sorted out!
It sounds like the engine is not running on all cylinders at low RPM. I'd escalate the issue if the dealer can't solve the problem.
