Question to 530d drivers. Acceleration.
My Ride: BMW 530d E60 '04
Hi Guys. i have a question to E60 530diesel drivers. I bought BMW 530d E60 '04. i am worried about acceleration of my car. Acceleration of my car looks like a spring. As if when i press the accelerator pedal the spring is squeezing (speed is growing up very smoothly), and then suddenly explodes (circa after 2000 revs) and abrupt acceleration. is this normal, what do you think? does everybody have the same?
Thanks!
Thanks!
Originally Posted by User_irl' post='521422' date='Jan 22 2008, 09:47 PM
Hi Guys. i have a question to E60 530diesel drivers. I have BMW 530d E60 '04. i am worried about acceleration of my car. Acceleration of my car looks like a spring. As if when i press the accelerator pedal the spring is squeezing (speed is growing up very smoothly), and then suddenly explodes (circa after 2000 revs) and abrupt acceleration. is this normal, what do you think? does everybody have the same?
Thanks!
Thanks!
If you are an experienced diesel driver, then ignore all of the above. Your car clearly has a problem!
Thanks!
Thanks!
Mine does the 'leap' at just over 2k rpm...
This is where the twin turbo's of the 535d make a difference and the boost is started lower down the rev range and the acceleration is more linear.
My previous car was a BMW 530d E39, also Automatic (but 5 speed). And on E39 i did't feel such sluggish at very low rpm. But E60 a lot powerfull after 2k rpm. Acceleration on E39 was more linear. Even from the start after kickdown E60 starts a bit slowly and around 2k rpm suddenly explodes and traction control starts flashing.
I gave the car to the dealler to check the engine and he said with the engine everything is OK. Now I'm thinking maybe there is some problem with gearbox? I did't check the gearbox yet. Or is it a big difference between 530d E39 and 530d E60?
Thanks.
My Ride: 530d Sport Touring (E61). Silver Grey, Automatic, Professional SatNav, Black Leather, Heated Seats, Folding Mirrors, 6CD changer, Bi-Xenons, Bluetooth
Thanks.
Thanks.
My Ride: 2006 530D SE; Mystic Blue; Beige Leather; Luxury Pack; Media Pack; Visibility Pack; 123's; Logic 7; + to many more to type...........
2008 730D; Black Sapphire; Cream Beige Leather; plenty of options!
...........Acceleration of my car looks like a spring.
My Ride: MY2004 530d. Poverty spec
I've got a late 2003 E60 530d. It's a manual, and I would say the turbo kicks in around 1800 rpm. It's a characteristic of a turbo car rather than a diesel (if you've ever driven a non-turbo diesel, not that there are many these days, you'll definitely notice the difference). Big-turbo'd petrol cars do exactly the same this - my Evo 6 had pretty much nothing until 3000rpm. Twin-turbo RX7 (see, BMW weren't the first to do it on a petrol car) was better, but still needed about 2300rpm.
You just have to learn to live with it really - it's easier in a manual I suspect, as you can control the revs via gear selection easier.
"Turbo lag" is more generally referred to as time it takes to respin up between gear changes - ie if you're redlining in 3rd and you change to 4th (revs maybe drop down to 3000), it still takes a while for the turbo to get back up to speed, as the suddenly shut throttle during the gear change causes the turbo to stall. Mitigated by dump valve, aka blow-off valve, which allows air to recirculate round the intake system thus avoiding turbo stall. I'm fairly sure the diesels have a recirculating dump valve (could be wrong), but they never stop lag entirely. This is also less of a problem in autos as you don't lift off so much during a gear change.
Anti-lag in a rally car is another beast entirely
. Pop pop pop bang.
Andrew
. Pop pop pop bang.Andrew
Originally Posted by Mike O' post='521656' date='Jan 23 2008, 07:06 AM
What you are describing sounds exactly like my car, also a 530d auto. I think that part of the problem is that in ordinary mode the gearbox sets off from a standing start in 2nd gear and nothing seems to happen until the turbo kicks in. Nowadays I put the gearbox in sport mode to pull out of junctions so I can avoid the problem of pulling slowly out in front of other traffic and then suddenly taking off like a scalded cat!
I never had an E39 to compare but like it's already been stated BMW had to tinker around with the responses for emission compliance...
My Ride: Current - 330 Sport Topaz Blue, Grey Leather, HK HIFI...lost interest!!
Waiting for - 535d Sport, Silver Grey, Foldy Mirrors, 172 19",Logic7,Pro Radio,Through load,Heated Front Seats,High Gloss shadowline,Black Maple,Headlight wash,Sun Protection Glass.
I have a 535d..lag no way near as bad as you described but still noticable, i cam our of a 330i petrol and i needed to get used to it, the smaller turbo does take a lot of the lag away...all but gone since DMS remap. A collegue with a 530d does comment that his kicks him in the back at about 2k rpm..maybe a remap?
Originally Posted by mixterk' post='521970' date='Jan 23 2008, 10:41 PM
... A collegue with a 530d does comment that his kicks him in the back at about 2k rpm..maybe a remap?
But after 2k revs - ...
Now I definitely can live with this.
