put distilled water in coolant reservoir that was at min level
My Ride: 2006 BMW 530I
Model Year: 530i
Do it yourself! It's easy! You got to start somewhere!
Here you go: DIY - E60/N52 Cooling system overhaul - Bimmerfest - BMW Forums
Let's assume the coolant system had 50/50 mix. An automatic transmission N52 has 10 liters. Let's say the reservoir holds one liter. If you has a dry reservoir and added only water, you now have 45% coolant and 55% water. That just isn't that much and should have very little impact on the boiling point. It will have a greater impact on the freezing temperature, but still not a problem for where you live. If you really want to empty the reservoir, go ahead and put in just pure coolant.
My Ride: 2007 BMW 530xi, 3.0L I6, 6-spd Automatic, 255 hp; 2011 Chevy Camaro 3.6L V6, Direct Injection, 6-spd Automatic, 312 hp
Remember race cars used only water for better heat-removal performance. Any over-heating is certainly not due to too much water percentage. We can't run pure water because of water pump lubrication and corrosion protection needs, as has already been said.
Yes you guys were right, my car was diagnosed with water pump failure and will need replacement + thermostat. My indy quoted me $873 which i think is a steal. Never happy to shell out a thousand bucks but I guess I was over-due
My Ride: 2005 530i, Premium Package, Grey Leather, Rear Euro Reflectors
![Question](https://5series.net/forums/images/icons/icon5.gif)
Model Year: 530i
You said about six months ago the water pump was replaced. Who did this and was there not a warranty? I'm not sure from the indy side since warranties can vary. But damn, six months seems too quick to fail again!
Model Year: 530i
I think only the thermostat is bad. OP did said he depressed the gas pedal, tested the water pump and heard it running. Not all mechanics know what they are talking about until they replaced enough irrelevant parts. lol
OP should show the mechanic how he tested the water pump first!!!
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
BigxPx
04-23-2015 10:11 AM
