Pulled some codes for fun.. help interpreting some?
My Ride: 2008 535xi
Engine: n54
Hey Guys,
So I had to help out my dad with his Audi to reset some things and I bought the carista app and dongle. That all went fine and dandy, but I decided since I had it I wanted to pull the codes for my 08 535 and I was surprised to get a bunch of codes. First of all I had my JB4 on and it rang up extra codes. Silly me, so I turned it to map 0 and re-ran it. I got the following codes and I can't seem to find some of them listed, and the others I'm still unsure what it's trying to tell me. Keep in mind that my car currently displays no CE light. I have, however in the extreme cold gotten the 2AAF fuel pump error a couple of times:
OBD2 - pending:
P0172 - System Too Rich Bank 1 <-- maybe because it was just startup?
Engine:
2AAF <-- had before in the cold
29E0 - Mixture control
2DED - Power management, closed circuit current violation
Transmission:
511B
5208
54C6 - VTG: oil wear
Heater & air conditioning:
9C55
Steering column:
951B <-- over voltage? But you know 2 years ago my tilt stopped working and I never got to the bottom of it, the gear doesn't seem like it's stuck, and I hear no more noise. Haven't probed for power but my assumption is the motor died and thankfully it's dead in my "default spot".
Car access system (CAS):
A0B4 - CAS: engine start, starter operation
Center console switches:
9FE1 - Steering column module: motor defective
9FED - Steering column module: initialized position data
Infotainment display:
E5C4 - K-CAN line fault
Gear selector switch:
A830
So if anyone wants to help interpret these couple to me I'd definitely appreciate it. I have coded a ton of stuff on my own years back, also flashed SAT transmission, but I wouldn't think it would affect anything.
I didn't reset the codes, although I would say if I did it would really just come back?
Thanks in advance!
OBD2 - pending:
Engine:
Transmission:
511B
5208
9C55
Steering column:
A830
Thanks in advance!
Engine: N54
So... reset them like you said and take it from there. no reason to put any more thought into than that.
My Ride: 2008 535xi
Engine: n54
Guess so.. just thought it was interesting to see/lookup those other ones and if it was a problem. Honestly if my car was newer or had less mileage I'd actually be worried about "oil wear"... I'll reset it and maybe check it again next week.
