Pulled some codes for fun.. help interpreting some?
Hey Guys,
So I had to help out my dad with his Audi to reset some things and I bought the carista app and dongle. That all went fine and dandy, but I decided since I had it I wanted to pull the codes for my 08 535 and I was surprised to get a bunch of codes. First of all I had my JB4 on and it rang up extra codes. Silly me, so I turned it to map 0 and re-ran it. I got the following codes and I can't seem to find some of them listed, and the others I'm still unsure what it's trying to tell me. Keep in mind that my car currently displays no CE light. I have, however in the extreme cold gotten the 2AAF fuel pump error a couple of times: OBD2 - pending: P0172 - System Too Rich Bank 1 <-- maybe because it was just startup? Engine: 2AAF <-- had before in the cold 29E0 - Mixture control 2DED - Power management, closed circuit current violation Transmission: 511B 5208 54C6 - VTG: oil wear Heater & air conditioning: 9C55 Steering column: 951B <-- over voltage? But you know 2 years ago my tilt stopped working and I never got to the bottom of it, the gear doesn't seem like it's stuck, and I hear no more noise. Haven't probed for power but my assumption is the motor died and thankfully it's dead in my "default spot". Car access system (CAS): A0B4 - CAS: engine start, starter operation Center console switches: 9FE1 - Steering column module: motor defective 9FED - Steering column module: initialized position data Infotainment display: E5C4 - K-CAN line fault Gear selector switch: A830 So if anyone wants to help interpret these couple to me I'd definitely appreciate it. I have coded a ton of stuff on my own years back, also flashed SAT transmission, but I wouldn't think it would affect anything. I didn't reset the codes, although I would say if I did it would really just come back? Thanks in advance! |
So... reset them like you said and take it from there. no reason to put any more thought into than that.
Guess so.. just thought it was interesting to see/lookup those other ones and if it was a problem. Honestly if my car was newer or had less mileage I'd actually be worried about "oil wear"... I'll reset it and maybe check it again next week.
