Puddle Lights.
I took out the plastic under door light housing, removed the bulb, drilled the hole where the bulb was, then soldered the wires to the bulb connections. Then you can just plug the housing back in and re-insert into the door. The best part is if you screw it up, it is literally the cheapest piece on a bmw to replace from the dealer, $21.99 at mine. lol
Edit: Yes, that's what I did
umnitza
Aug 20, 2015 04:34 PM
