Programming E60 Key Fob
My Ride: 2004 525i
hate to bring this zombie thread back to life, but I just got a new blank key from a place here in ohio that sells aftermarket replacements. I haven't been able to get it programed by the methods in this thread(I'm going to try some more later today) I have a 2010 e60 without comfort access. It only came with 1 key so I figured paying $25 for another to try out wouldn't hurt. Does anyone have any updated instructions?
My Ride: 2010 e60 535i xDrive sport/premium Monaco Blue with Brown leather.
The local shop actually had a Zed programmer(big bux and really awesome) Unfortunately, my build date was just old enough that they would have had to pull the security module from my car and wire it up to the programmer. The newer models can do it from the ODB2 port though. mines a 2010 e60
My Ride: 2007 BMW 530xi
Sorry to revive an old thread but I wanted to add some information.
Programming a key to your BMW's CAS will cost you money, regardless if you DIY or pay someone to do it. The tools for you to DIY will be in the $200 range for Chinese clones and the process takes 15 min.
1: It's FAR easier to program a virgin key than a 'used key'. Virgin comfort access and non comfort access keys are $15 USD on Aliexpress.
2: A used key will need to either have the transponder de-soldered and a new one soldered in ($4 per transponder chip) OR you can purchase a PCF79xx Unlocker, or Xhorse VVDI PROG Programmer, and fiddle around with that to erase the data from the transponder. As you can see, you're better off buying a virgin key!!!
3: You can use HiTag2 to prepare a blank key and create the file for use in BMW Explorer/EF Scanner.
4: With a battery tender/charger on your car, use EF Scanner to program the new key to the CAS.
5: If you're on a budget you can get your key blade cut/copied at a local lock smith for ~$15 USD... otherwise you can buy a Defu 368a key cutting machine.
Here's how:
Here's how:
FuzzyWuzzy (02-25-2021)
Probation Members
My Ride: 2007 530i sport w/ comfort access
I've got a 2007 BMW 530i w/ comfort access...my circuit board was damaged, but the transponder is still in tact. My question is, if I were to buy an OEM blank could I have the original transponder soldered onto the new blank board and it work without any additional programming? I saw it briefly mentioned earlier, I just wanted to confirm..before I went to the dealer.
