Professional Sound System
My Ride: 06 530i Premium and Cold Weather Package
Orient Blue, Tan Interior
Not so good.....
I am not sure if there is an amp in this system but if there is can anyone suggest a good replacement one?
I just want to go that far and replace or install an amp where the manufacturer would have. I had an issue where my bass dropped quite a bit during a road trip, took it to the dealer and they found it to be operating within spec. They even went as far as to compare my car with another of the same spec and year and found it to be the same. So I am looking to see what I can do to get the system sounding better. Thanks!
Originally Posted by SCardamon' post='877235' date='May 13 2009, 05:16 PM
Not so good.....
dont know if this helps
this one is the easiest install by far,
http://www.tyresmoke.net/forum/bmw-5-6-7-s...e-e60-535d.html
and try these too
http://forums.e60.net/index.php?showtopic=11606
http://forums.e60.net/index.php?showtopic=47747
i have upgraded many car audio system in the past, but it seems that the e60 is a diffcult car to work with but the first link is will do the system for about ?650, and you will probaly get the best results.
hope that helps
My Ride: F11 -14
Thank you everyone for the help, just took the write up of all three systems and mailed the dealer. At one point my bass quality dropped and I thought it was an amp issue, then they told me I had the professional system which did not have an amp. I have the 10 speaker system so I obiously do not have the standard audio. Will be interesting to see if they can help out. This is a difficult warranty item to help with.
Thanks agian
Thanks agian
incoherent
04-15-2015 04:48 PM
