problem taking wheel off
Old Jun 13, 2008 | 01:48 PM
1fasts14's Avatar
ok i bought set of wheels, i go to take my stocks off, take lugnuts out and the wheel wont budge am i missing something lol or is my car a retard thanks... this is no joke
Old Jun 13, 2008 | 02:03 PM
1fasts14's Avatar
is there a pin i have remove im serious
Old Jun 13, 2008 | 02:07 PM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
No pin. The wheel has just become stuck. I had to change a flat once and it took a LOT of very hard kicking on the tire to finally break it free. You gotta hit them hard. The tires that is, unless you have a rubber mallet and can hit the wheel itself...
Old Jun 13, 2008 | 02:46 PM
CWS530's Avatar
The wheels are hub-centric and rust particles collect over time and the wheels stick. Before you throw your back out, try taking one of the wheels/tires you just bought and gently swinging the tread at the sidewall of the stuck wheel. If you have an old tire around, that will work as well. Or, lie on your back facing the car feet-first like you're getting ready to do a leg press and kick the crap out of the sidewall with your heels. Just be ready to react when it comes loose. Good luck. Also, to prevent this in the future, clean the rust from the hub and apply some anti-seize or other lubricant. Next time, they'll come right off.
Old Jun 13, 2008 | 03:00 PM
DrLev99's Avatar
...or try lowering the car with a few loose lug bolts installed, but not all of the way. The weight of the car could be enough to pop the wheel loose. If that doesn't work, smack the crap out of it!
Old Jun 13, 2008 | 03:12 PM
acuteperformance's Avatar
My Ride: 14 550i
sit down on the floor and then kick the side of the tire alternating between sides. it'll come right off.
michael
Old Jun 13, 2008 | 03:43 PM
mhs525's Avatar
My method:
Jack up car, remove lugs, place block of wood against inside of rim (wood won't damage the rim), whack the block or wood with a small sledge hammer. Wheel pops right off with no damage.
Always clean hubs and cover with a coat of grease before installing new wheels.
Old Jun 13, 2008 | 05:00 PM
1fasts14's Avatar
thanks for the input i just kicked the shit out of them till they came off, now my breyton race gts in black 20's look badass on the silver gray.
Old Jun 13, 2008 | 05:44 PM
DRANGED's Avatar
Old Jun 13, 2008 | 05:51 PM
DrLev99's Avatar
Originally Posted by DRANGED' post='602278' date='Jun 13 2008, 09:44 PM
+1
