Preventing Oil Leaks
#21
My Ride: 2015 535D M Sport
Update: This a.m. I set up the hidden menu and checked the coolant temp again. It never got over 95C and once warm fluctuated between 90-95C with AC on and in the low 70'sF outside. I wonder if I have a colder thermostat because I picked the car up in Germany, even though it is full U.S. spec.
#23
My Ride: 2008 550i
Almost every problem on BMWs that requires a part to be replaced centers around the crappy rubber they use, and it isn't just isolated to oil sealing gaskets, nor to rubber components under the hood.
#24
#25
For example? I haven't had anything fail so far. My '98 e39 has only had the windshield gasket and valve cover gasket go bad. It's 16 yrs old.
#26
My Ride: 2008 550i
The windshield washer pump went bad and leaked after just 3 years. I broke it apart and found out the internal o-ring failed. And I too had to replace the rear windshield seal after 5 years.
Those are pretty early timeframes for those parts to fail.
I've also resealed the vacuum pump, which started leaking at about 4 years. I just replaced my water pump. And now my transmission pan gasket is leaking and needs to be fixed.
Sounds like some people seem to be lucky and others aren't. Maybe BMW has several different rubber parts suppliers? Some good, some bad, who knows.
#27
My Ride: 2008 550i
I think BMW knows that their rubber quality is bad, because they seem to release newer updated parts for certain items. The windshield washer pump has a newer part number now, and the mechatronics sleeve part was updated with newer and completely different rubber seals.
#28
My Ride: 2008 550i
Doubt it. My 2003 TL was spec'ed to use conventional oil with a 3750 mile hard usage and 7500 mile normal usage change interval. I switched to synthetic on my own with my own 10K mile routine because I only wanted to change oil once a year. I do 10K on my BMW too.
#29
#30
I don't think 220* is right, that's pretty high. As I recall, when I used the hidden menu to display my coolant temp, it climbed up to the low 90'sC and got no higher than 100C while driving. I'd guess it averaged 95C = 205F.
BMW WAHLER Thermostat with Housing and O-Ring (105 deg. C) 11537586885 - RM European Auto Parts
Also, even BMW's own documentation on the N62 engine shows temps that high being normal and "more economical". It has several different modes, the highest temp/most economical one being in the 220 range. For the performance modes the computer can bring the temps down
