Pre Lci Halogen to Lci Bi Xenon
So i need some help on splicing the connectors.I have the oem retrofit kit. The car has 7 wires to each headlight, The lci bi xenon headlights i purchased are adaptive although i do not plan on using that feature. If someone could explain to me exactly wire to wire that would be appreciated,Thanks.
http://s27.postimg.org/j5k3erm0v/IMG_1761.jpg |
Search DIY section
I have searched and searched. There are a ton of random posts but none with legit information on exact wire to wire install.
Look at this post to get to wiring diagrams:
https://5series.net/forums/e60-discu...1/#post1547026 |
The link doesnt have the wiring diagram for xenon e60 headlights. Any other information from members who have completed this retrofit would be appreciated!
1 Attachment(s)
Navigating that web site isn't the easiest...I went there just now and pulled this up.
Im having no luck navigating that site. I need a diagram to retrofit from pre lci halogen to lci bi xenon.
Here might be something you are looking for:
And the PDF instructions: |
Thanks, Ive recently read through those posts. The issue im having is my harness has one headlight connector. The xenon cars have two connectors with more wiring. I know a few guys on here have done the conversion, hopefully they'll chime in soon
http://s29.postimg.org/meu25wbw3/bmw_rain.jpg :rolleyes: |
1 Attachment(s)
Take a look at this wire diagram that I found. Are you talking about the pin 1 (brown) for Xenon only from the diagram? From what I know of our E60, brown is ground wire. I might be wrong, but I think that might be the dedicated ground wire for the Xenon ballasts.
