pothole hit-now leaking?
Old Dec 3, 2005 | 11:03 AM
vpbmp's Avatar
My Ride: 2002 545i sport pckg,sirius,active steering,grey on black
The other day I bottomed out on a pothole and now have a slow leak. I've since
localized it. In front of the forward [in this case]right wheel there are two semi horizontal
arms, an upper one[w/ a "do not tow"sticker] and a lower one . The lower arm connects
to a box like structure under the engine at a joint, and the leak appears to be coming from
some seals at the junction of the arm and the box. I have an appt in one week w/ my
dealer. Does anyone have any ideas ----is this engine oil? steering fluid? lubricant from
a joint?
Thanks
Old Dec 3, 2005 | 11:13 AM
BMW#7's Avatar
Not sure - but your dealer should book your car in as an emergency & not make you wait a week. It could be dangerous.
Old Dec 3, 2005 | 11:43 PM
FJPM's Avatar
My Ride: 535 D - to be delivered end Feb 2005 - color E08 - comfort seats - executive leather balck - 122 wheels - dynamic drive - active steering - pack luxe - tecnology pack - moon roof - 6CD player - hifi system - spare wheel - BT phone
I have not seen it but if I rember well the arms are connected to thr body through "hydraulic" joint. Maybe you have damaged one. Anyhow do not mention the pothole to the dealer he could use that to void the warantee on this issue, which is not acceptable because a car like that has to resist to a pothole.
Old Dec 5, 2005 | 10:59 AM
5 Rakete's Avatar
a joint?
Thanks
What exactly do you mean by a leak? In other words describe the fluid/whatever. There are two lower suspension arms, a front and a rear. The other arm you refer to sounds like the headlight level sensor which would make sense to have a "Do Not Tow" sticker on. The front lower suspension arm (actually called a "tension strut") attaches to the front axle support with a sleeved rubber bushing and a bolt. It doesn't look like it would be a lubricated fitting from the parts catalog. If you are seeing a leak from there I would be a little concerned that its coming from somewhere else. I wonder if it might be Active Roll Stabilization unit on the front stabilizer bar. Need to know what the leaking stuff looks, feels, and smells like.
PakiBeamer
Dec 9, 2016 04:40 AM
abrookey
E60 M5 Discussion
Sep 22, 2015 05:05 PM
subieworx
Sep 21, 2015 01:19 PM
E60king
Sep 13, 2015 05:25 AM
ST JAMES
Sep 4, 2015 04:54 PM
