poor mpg 2004 525i
My Ride: 535i
i appeciate all the help , changed the spark plugs = got 2-3 miles improvement , tire pressure - never checked unless computer messaged me , have to check air filter and work on the maf , btw rotors are bit rusty on the inside (car is bit shaky when braking at higher speeds).will keep you guys updated
thanks again
thanks again
My Ride: 525i
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
The flat tire warning doesn't go off when all the tires gradually lose air over time (on the 2004 - no pressure sensors on the wheels). You have to check it manually. The FTM works by observing changes in differential rotation rates.
The 2004 has the M54 engine, I believe. At that age and mileage you probably need new VANOS seals. That causes bad MPG, and it's a well-known problem on the M54. Get a set of seals from Beisan Systems - better than OE.
i have only 80k , mpg dropped significantly , normaly i was making about 400-440 on tank , after 4 month in the garage .... 350
, changed spark plugs today , ...any other suggestions...?
tire pressure ok , have a minor leak on engine(mechanic quoted $300 labor and part(only $20), told me it is normal for all bmw since the gasket is getting dried after awile)... oil level ok all the time ....computer shows 18-19mpg , dont floor at all
Could be a valve cover gasket leak. If you're so inclined rip the car apart and clean it.
