plug in front of car
I have a plug (a standard 3 prong outlet) behind the grill in the front of my 550. What is it? Is there a built in block heater to keep the engine warm during winter? Does everyone have this and has anyone ever used it?
My Ride: 2004 530i
premium package/active steering/auto sunshade/tiag/black dakota leather/logic 7
35% tint all around
19' DPE GT7
my guess is block heater, however I didn't think there was a block heater available from bmw for your car. It could be aftermarket, just check to see where the cord runs too. I have a oem block heater on my car but I have the older m54 engine. I also know that my dealership installs small trickle chargers this way, used for keeping batteries full charge in the winter. If it is a block heater the cord should run close to your oil drain plug as thats where the oil pan is.
Originally Posted by EV4530' post='1084095' date='Jan 4 2010, 05:45 PM
Can you show us a pic?![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
However, you should check to see what type it is. If it is a dipstick heater, remove it. [I do not have personal experience with it but] the folks on the 3-series and e24 have nothing nice to say about dip stick heaters or the people that use them.
The dipstick heaters tend to scorch the oil where they make contact in the tube...
In the e24 there was a freeze plug that you could install a resistive heating element to warm up the cooling fluid for cold days... HERE
My Ride: 2006 titanium silver metallic
Like new 41k
Cold Weather Package
Originally Posted by or_550i' post='1084124' date='Jan 4 2010, 06:10 PM
Since you're in the Great White North, it probably is an engine block heater.
My Ride: Bmw 530d 2004
Originally Posted by D33ZNUT5' post='1084573' date='Jan 5 2010, 09:32 PM
Most likely an oil pan heater. You cant get a block heater on an E60.
Like new 41k
Originally Posted by Anzafin' post='1084586' date='Jan 5 2010, 02:47 PM
Here the importer installs a block heater to all BMWs. Actually it's the same with all other brand importers too.
My Ride: 2004 530i
35% tint all around
19' DPE GT7
Originally Posted by D33ZNUT5' post='1084628' date='Jan 5 2010, 02:33 PM
It's probably not a block heater. I dont think the engine even has a spot on it to install one. Probably oil pan heater.
I know for a fact that you can get block heaters for older e60's, I just installed one on my car but I think you have to have m54 engine. As for the OP you are probably right in that he likely has a pan heater because he has a newer e60.
