5Series.net - Forums
-   -   Please help me (https://5series.net/forums/e60-discussion-2/please-help-me-148734/)
Reverse Polarity Jul 24, 2018 06:50 AM
Please help me
Ok I have a question maybe you can help me with I was driving my car the AC fan stopped blowing and then it said transmission malfunction towed it back to my house then the battery was dead so i charged it I drove to Baytown about 18 miles then to nrg stadium about 35 miles then home again the next morning battery was dead jumped it it's then before I left my drive way it said transmission malfunction code p1890 and I heard a snap and it wasn't my Serpentine belt any ideas?
JayArras Jul 24, 2018 07:20 AM
An old battery manifests a slew of different codes and errors. The first thing I would do is remove it and have it tested at an auto parts store. If you need a new one, Auto Zone and Advanced have very good prices on BMW batteries. There are a number of threads here on what you need and what to do. Install it and get it registered. A BMW indy should be able to do it for under $50. Have them clear the codes and see if it clears up the problems. If not, you have other issues.
LessIsMore Jul 24, 2018 08:30 AM
Sounds like your alternator is dead. it's running off only the battery which is why it keeps dying.
No idea on the "snap" noise - I'd figure out the dying issue first and see if you still have others afterward.
vmann Sep 10, 2018 02:15 AM
Its the hedgehog sensor.
Check and replace this.
vmann Sep 10, 2018 02:16 AM
This is not working correctly, therefore when you switch the car off the heater fan stays on, draining the battery.
