PLEASE HELP! E60 won't start and it was working an hour ago.
My Ride: bmw 530i e60
![Angry](https://5series.net/forums/images/icons/icon8.gif)
hello all, i need help on my 2007 530i..
So at first my car was all fine and dandy..
All i was gonna do was to replace my reverse bulb because one went out.
unfortunately we got the wrong bulb from autozone, so we left that out.
Since we didn't do anything, the other problem we wanted to try and fix was my non-working honk. My honk does not BEEP.
after looking at the manual, i still couldnt find where to locate the problem or how to fix it.
So i went to my Fuse box in the glove compartment, my dad was pulling and re-inserting the fuses where they were, after that.. he left and still no beep...
Now since he left, i wanted to go to autozone on the e60 since we got the wrong reverse bulb , and now i insert my key and try to push to start and NOTHING HAPPENS.
I WAS SO PISSED b/c my CAR was running earlier today, and now it doesn't even want to START.. I DONT KNOW WHAT TO DO, and i need assistance
When i insert my key no light turns on, my windows wont go down or anything,
attached is a picture of my fuse box, can you please check it out and make sure every fuse has to be in their respective fuse location.
Check the tool storage area on your trunk lid. There should be a sheet diagram listing the fuses for your car as built. This sheet will show both the glove box and right rear panel in the trunk fuse layout...
Good luck.
Good luck.
