Please Help
For the "Driving stability" warning: check the Power Steering/Hydraulic Fluid level. Cap may have a Green Ring on it and say "CHF-11S" This supplies the Power Steering and Dynamic Drive (ARS) that your warning is about. There should be a dipstick attached to this cap. You can buy a pint of CHF-11S from the dealer. Brand is Pentosin.
Otherwise, could be electrical (weak battery). This causes several seemingly unrelated warnings to pop up in iDrive.
Don't know about the "Start-off assistance"
My Ride: Modded 2010 Carbon Black M5 SMG and Modded 2008 Dinan 550i Sport
I believe you have braking system errors. This would be easy diagnosis at a decent Indy or dealer.
My Ride: 2006 525i M Sport
Carbon Black
Cream Leather Interior
These warnings appeared on my car regularly, with no sign of anything wrong or different about the car performance or handling, I believe they could be related to a weak/dying battery. I've had a software upgrade recently done on my car, it should sort it all out.
Look to battery or alternator first, because one relates to hydraulic fluid and one to braking system.
When fault shows up again try stopping, turning off engine, removing key, waiting 10 seconds and then restarting. If fault is gone it points strongly to dying battery or alternator not charging it.
My Ride: 05 BMW 530I
+1
My Ride: 2008 550i Alpine White
Thank you for all the replies. I just started the car and the messages are gone. Then, I took it out for drive 15 minutes later the messages reappeared. Now the new dilemma is battery replacement. There's so many threads regarding battery getting register or not.
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
I get the stability error from time to time mostly in the morning when cold or after a hard rain. After the car goes to sleep it clears the error, no ryme or reason other than the two senarios that I stated. Never heard of the other error message, and by the way I have a new battery from the dealer and it was registered
