Play MP3 data DVDs in CCC Pro Nav 2007?
My Ride: N/A
I burned a data DVD full of mp3s and it won't play in the DVD slot of my 2007 LCI 535d. It's idrive w/pro Nav CCC (update 1 with the favourite keys). Video DVDs don't work either but I'm not sure if this system can play those. Mp3 DVDs though I thought were a go-er.
Apologies: found it very difficult to research this on the forum as 3 letter searches are barred - 'ccc', 'mp3', 'DVD', 'nav', etc!!
![Doh](https://5series.net/forums/images/smilies/imported/doh.gif)
My Ride: N/A
Done further reading and sure this shouldn't need coding on a 2007 LCI.
I'll try with an MP3 cd and see - presuming if mp3 CDs work then 'MP3' is enabled and I'll try some different DVDs and burn options. Will update thread with results for others ref.
My Ride: N/A
I've tried with a new DVD burnt at 2x with only a handful of files and finalised the disc. Also burnt a cd in the same manner. Neither will play in either drive.
I've read on another forum that it needs to be enabled via coding, so will look in to this.
Ref: BMW: E60 - IDrive Version Number -- (Diagnostic photos in thread) : BMW 5 series Forum • BMWLand
I've burnt data discs and they didn't play while others played. It's been many years so i don't remember but I think they are CD-R and there were a few folders. Played in both CD and DVD. I don't really listen to music much anymore and when I listen to audio files it's on my iphone/aux. So wish i could be more help. Have you ever played an MP3 in this car from a CD? Chances are you need to have it coded to do so. You'll have to see your vehicle order and/or management files. Is it possible? yes. For you? I don't know
As far as video, no they won't play for you.
My Ride: N/A
Thanks again very much for the info.
Never played an MP3 from a CD/DVD. Coding seems funny as the manual specifically states it should play "compressed audio files" on the CD drive (but no mention of DVD).
That said a D CAN cable is £22 delivered on eBay so might give that a spin. Sure I'll find some setting to change to make it worthwhile even if mp3s are a dead end!!
My Ride: N/A
OP delivery time.
1. Burned an MP3 CD and DVD using Nero Express in 'Audio Jukebox' mode, both work in the car.
2. The £22 eBay cable works a treat for coding and despite some mega-bed-time-reading this was pretty easy to get going - so anyone thinking about it should get involved.
rackhacker9275
04-06-2015 04:55 AM
