Is Pentosin Auto trans fluid AFT 1 okay for my car?
My Ride: E60 2006 sedan auto
I am having real trouble in Japan finding any transmission fluid to suit my car
a 2003 E60
everyone just says take it to the dealer
I went to a BMW dealer who at first wouldnt sell me any and then wanted aprox $70 usa a liter
so a mechanic suggested i use Pentosin Auto trans Fluid ATF !
does anyone know if this fluid is okay?
I found some on line sellers saying it is
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
Thanks for your help
a 2003 E60
My Ride: 2006 BMW 550i
should be good
read this thread i made a while back. ford mercon sp is the cheapest option if you can find it over there.
https://5series.net/forums/e60-discu...arison-115742/
should be good
I will order a new sump and sealing sleeve and do it all togeather
I will get the Pentosin ATF1 as its easy for now but if it is all working well after i give it new oil ect I will probably change to a better fluid and hopefully if I look after it,
As turboawd indicated, if you can find the Ford Mercon SP fluid that is the best option as it is chemically identical to the ZF Lifeguard fluid.
http://www.bimmerfest.com/forums/sho...d.php?t=441992
You'll be fine with the Pentosin fluid. It is not technically approved, but it is a good transmission fluid none-the-less. I wouldn't bother changing the fluid out to another brand once you have used the Pentosin, just do a simple drain and refill to get as much new fluid as you can in the transmission.
Another alternative to the Pentosin is Valvoline MaxLife ATF. It meets the Shell specification for the ZF transmission fluid.Contact the local Japanese distributor for more information. It might be a less costly alternative to the Pentosin.
Valvoline.com > Trade Partners > Worldwide Distributors
socale39
09-05-2023 08:30 AM
chadillac2000
42
09-13-2017 11:15 AM
