PDC problem
Old Aug 5, 2019 | 12:08 AM
d0n_pietro's Avatar
My Ride: 530dA 160kW
Engine: M57
Unhappy PDC problem
Hey guys, I have a problem with PDC which noone was able to help me with for like a year in my country. The problem is, that when i shift into reverse, the PDC detects the objects and beeps, but nothing comes up on iDrive screen. I do even not have PDC option in my iDrive settings
Does anyone have suggestions about what could be wrong? When I was buying the car from dealer, the PDC on iDrive came on, but then never again
Old Aug 5, 2019 | 04:13 PM
audiophool's Avatar
My Ride: 535xi
Does it work if you're stopped and you press the PDC button?
Old Aug 5, 2019 | 09:35 PM
d0n_pietro's Avatar
Engine: M57
The PDC comes on and beeps, but it wont come on on iDrive screen, also there is no PDC option in the settings.
Old Aug 6, 2019 | 05:07 AM
audiophool's Avatar
My Ride: 535xi
Sounds like your iDrive isn't configured for PDC although the hardware checks out.
Old Aug 6, 2019 | 05:29 AM
d0n_pietro's Avatar
Engine: M57
Sounds like it...it worked once when I was buying the car tho'.
Is anyone willing to help me with programming the PDC to the iDrive? Share some NCS files?
Old Aug 7, 2019 | 05:12 AM
audiophool's Avatar
My Ride: 535xi
I guess you could ignore the problem. When I'm using PDC, I rarely look at the display anyway, I just listen to the beeps from the stereo - they play from the corner the sensor senses.
But I hear you - I like to have ALL of the things working. Once you let one fault persist, others don't get the attention they deserve. (4x4 light has been on on our old X5 for 2 years. Finally got a good scanner and it's saying the SAS is bad. One of these days...)
Old Aug 16, 2019 | 08:01 AM
funglenn's Avatar
My Ride: 530ix
Model Year: 2020
do you know how to program it? the trick is having the software and such. i can help or you can use NCSdummy which walks you through each option. The CCC also has options to show the PDC on the screen in horizonal or vertical. ....
Sandres
Jul 4, 2016 02:47 PM
MAD ANDY
Feb 15, 2013 07:39 AM
delje08
Oct 9, 2008 11:00 AM
AlexFW
Oct 22, 2006 10:01 AM
GadgetKing
Nov 24, 2004 03:32 AM
