PDC not working!
do you get an error on the i drive? or a blinking green light on the button?
if not its just your setting in the idrive menu.
no green light or anything. on my i drive sttings the only menu i see for pdc is a button that says enabled. am i suppose to be looking somewhere else. c.joe was it expensive to get it fixed..
If you put get a friend to put the car in gear you can tell which sensor is not working by putting you finger on each one. You should feel a light 'clicking' or 'pulsing' under you finger. The one that doesn't work will won't pulse.
You could try spraying the outside face of the faulty sensor with WD40, that might cure it. Someone on here did that to a faulty PDC sensor and it worked well.
Vman33
03-14-2022 04:43 AM
Trinity Autosport
09-22-2016 11:08 PM
bestofthebest
01-05-2016 07:47 PM
