PDC Malfuntion
Old Aug 24, 2010 | 09:54 AM
Bimmerchop69's Avatar
My Ride: 2004 BMW 545i 6mt, Titanium Silver, Sport Package, Winter Package
Ok so for a couple of months my PDC has not worked. It started with working and then not working to them working again and eventually just stopped. Since it is just a convenience feature, I really didn't care, except for the fact that its is terrible annoying every single time I start the car the car notifies me of the malfunction. Can you please let me know what can possible be wrong with the PDC? I have a 04 545i w/88K miles.
Old Aug 24, 2010 | 09:55 AM
Oh and is there any way I can test the sensors to see which one is bad?
Old Aug 25, 2010 | 05:11 AM
No one can chime in on this? seriously.
Old Aug 25, 2010 | 06:35 AM
mustafa550i's Avatar
I took mine to the dealer because the PDC kept displaying tire presssure warning. It turned out to be a bad sensor. I am not sure how to check for a bad sensor. Good luck!
Old Aug 25, 2010 | 09:03 AM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
If I am not mistaken it could be anything from a bad sensor(most likely) to a bad or faulty MPM. I would say the dealer is the way to go.
Old Aug 25, 2010 | 11:43 AM
I was dreading you were going to say the stealer. I'll just deal with the issue.
Old Aug 25, 2010 | 12:14 PM
Theo's Avatar
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
A friend of mine was able to locate the faulty sensor in his '03 by listening, it made a buzzing sound from closeby. Ordered it through the independent specialist, retracted the rear bumper somewhat, replaced sensor and no more issues...
As for a module malfunction, check your booth for water (lower trunk area, in the spare wheel well). The PDC module is located at the bottom towards the rear in the mold, most vulnerable location when there is moisture in the car...
Good luck!
Old Aug 25, 2010 | 12:22 PM
I will check thank you for the insight
Old Aug 26, 2010 | 05:29 AM
Good luck!
So yesterday I turned on the PDC and listened to each sensor. Closely, I heard a ticking noise coming from all the sensors except for 1 in the back. Pretty sure its that sensor since it is not working (ticking), Thanks for your help.
Old Aug 26, 2010 | 10:20 AM
Theo's Avatar
That's promising news... Be sure to let us know if you were able to fix the problem by exchanging it.
