5Series.net - Forums
-   -   PDC Malfunction error just appeared (https://5series.net/forums/e60-discussion-2/pdc-malfunction-error-just-appeared-122046/)
Shlooky Mar 21, 2012 08:00 AM
I put the car in reverse and got the error displayed in the center console as well as the flashing PDC button.
Anyone experienced this? Is it a costly repair?
Thanks
rkoenig Mar 21, 2012 08:18 AM
Thanks
Found some good info in this thread on another forum:
http://www.bimmerforums.co.uk/forum/...isplay-t36419/
HTH...
jaycal3 Mar 21, 2012 08:48 AM
I would check the connection to the sensors under the bumper...
Shlooky Mar 21, 2012 08:52 AM
I will do that, thanks.
Shlooky Mar 21, 2012 09:48 PM
I tapped on the censors, started the car and all is back to normal, PDC works even if I reverse. Sigh!
YeeeHaa Mar 25, 2012 11:23 AM
Has your problem returned since you "tapped" your sensors?
I'm having this same problem on the two middle rear sensors.
Light above button flashing
Tapping hasn't worked for me
Shlooky Mar 25, 2012 08:23 PM
Yes my problem returned, so it's intermittent. I will have to troubleshoot further, could be one or two sensors.
YeeeHaa Mar 26, 2012 12:43 AM
I'm also asking around, since I have the very same problem, I'll keep you in the loop.
Have you tried checking the connections to the sensors?
ya5 Mar 27, 2012 01:27 AM
TBH .. sensor is failing .. will work on and off for a little while, and then eventually stop working altogether..
Sensor will require replacing .. easy enough to do .
