5Series.net - Forums
-   -   pdc (https://5series.net/forums/e60-discussion-2/pdc-92042/)
podcauro Jan 10, 2010 10:33 PM
pdc on e6o doesnt work.. any ideas????
turboawd Jan 10, 2010 11:08 PM
could you be a little more vague? :huh:
DD_545i Jan 11, 2010 05:22 AM
Especially in the subject line. It's marginally better than those that have the subject line of "help!".
Many more details are needed for anyone to offer suggestions.
podcauro Jan 11, 2010 07:42 AM
hi there. One of the front sensor failed to work in cold weather,but no PDC FAILURE was showen.. I tryied to open it from outside(was using screwdriver)... Anyway, i couldnt open it and warning message came on straight away.. DID I DAMAGE THE ACTUAL SENSOR? is it pricy job????
BlaSTiWi Jan 11, 2010 08:55 AM
Its quite common for PDC sensor to behave strangely in cold weather especially if there's frozen moisture ... the sensor is actually pop inward as oppose to outward (after you undo the clip behind the bumper) ... the fact that it wasn't set off any PDC warning before and after mocking around w/ screwdriver now there's warning ... yes ... quite possible you damage it during the process.
Each sensor maybe not that pricy but labor to replace it maybe, depend on the location it may require bumper removal or atleast the front grill or headlight ... to be exact check with your dealer.
GL!
