Sponsored by:
Sponsored by:
545i Rear metal/metal clunk on acceleration
Old 05-24-2018, 11:17 PM
iamdavincity's Avatar
My Ride: 545i Sport
Model Year: 2005
Default 545i Rear metal/metal clunk on acceleration
Hey guys so car has about 160k and when I accelerate very slowly you can hear this clunking/creaking metal to metal noise in the rear end, basically it does it any time the car shifts weight, so like when going 5mph and slowing down it does it. It's an SMG 6 Speed Manual and it doesn't do the sound if the car is in neutral ...only when in gear and jerking back and forth with the clutch will make it go faint clank clank clank like plates hitting eachother. Any ideas? Nothing in the rear suspension has been replaced honestly I don't think probably ever so it could use some bushings I guess lol?
Old 05-27-2018, 06:04 PM
audiophool's Avatar
My Ride: 535xi
There's a splined slip joint in the driveshaft. Could be dry.
Old 05-28-2018, 01:26 PM
captainfreezy's Avatar
My Ride: 528i
Model Year: ‘08
check your battery compartment in the trunk and see if your battery can slide around. i had the same issue with a clunk on acceleration/braking and it turned out to be my battery moving around because one of the battery hold-downs weren’t installed
Old 08-09-2019, 11:23 PM
gfactor's Avatar
My Ride: 2005 545i
Did you ever figure this out? Have the exact same thing going on with my 545i 6-speed manual.
Old 08-10-2019, 07:38 AM
audiophool's Avatar
My Ride: 535xi
Can you duplicate the noise when stopped and have the hand brake set? Load the drivetrain in first and reverse?
Get the car up on ramps, then grab the drive shaft and turn it back and forth by hand, listening for noises. You may also want to try the center joint area if it's accessible.
Old 08-10-2019, 11:06 PM
gfactor's Avatar
My Ride: 2005 545i
I have only noticed the sound when moving off or slowing down from an already low speed. So if I'm in stop-and-go traffic, you will hear the sound with every change in acceleration or deceleration that causes the weight to shift. At first, I thought it was the engine mounts but recently learned that the sound was actually coming from the rear. I'll try loading the drivetrain with the hand brake set and see if I can duplicate the sound. I'll also get the car up in the air within the next few days and try your other suggestions. Thanks.
Old 08-22-2019, 06:20 PM
08E60550i's Avatar
My Ride: 550i 6mt
My manual has the same issue and it is kind of embarrassing at low speed. Every time I left off the clutch it starts to clink/ping/ring or a quick lift of the throttle - anything that load or unloads the driveshaft. There is a small note in the Bentley manual about greasing the input shaft in the differential as audiophool mentioned. Only problem is I don't have the time to pull the exhaust to drop the heat shields to get in there. Keep us posted!
Old 08-30-2019, 10:26 AM
gfactor's Avatar
My Ride: 2005 545i
Nothing seems amiss with the driveshaft. The center support joint seems fine and I could not recreate the sound from turning the driveshaft back and forth or by pulling on it in a few directions to check for looseness. I'll get back under the car this weekend and fiddle with the driveshaft some more before totally ruling it out. I will probably also replace the giubo and center support anyway since I am this far in. Stay tuned.
IceBimmer
07-16-2010 06:29 PM
mokk76
04-19-2010 06:12 PM
e60fanman
02-23-2010 03:01 PM
AlexFW
02-07-2009 11:46 PM
Bre Ced
05-12-2004 07:53 AM
Quick Reply: 545i Rear metal/metal clunk on acceleration
