5Series.net - Forums
-   -   Pathway Lightning (https://5series.net/forums/e60-discussion-2/pathway-lightning-973/)
mlist84 May 3, 2004 09:16 AM
hi guys, im really stucked in this "pathway lightning" matter. on the i drive menu under "lightning" ; i've set the time to 20s. but i got nothing soon after i turned off the engine and locked my car. there is no pathway lightning..i wonder how it works?
any of you try this?
kiran May 3, 2004 09:23 AM
After removing the key press the headlight flasher. that will leave the lights on for the set time.
Cheers,
Kiran.
mlist84 May 3, 2004 09:27 AM
OMGl.. so i need to push in order to be able to have that. i thought i just need to press the lock button or just remove my keys and the light is goes on like the other car such as mercedes benz...its weird.
thanks though.
cidair May 3, 2004 12:08 PM
My pathway lighting works as soon as I lock the car with the remote!
pbarch1 May 3, 2004 12:13 PM
I had the same problem after my software update. I think that I pushed the overhead lighting buttons until they were in the correct position and all of a sudden the pathway lighting started working again. give it a try :)
BMW530 May 3, 2004 01:24 PM
The "Follow Me Home" function i.e. pathway lighting is activated via the headlight flasher as mentioned after the engine has been turned off. This was the same as on my E46 320iSE and 325iSE. I was not aware of the remote activating this "follow me home" function. The remote will only activate the interior lighting as far as I know.
sj3 May 3, 2004 02:44 PM
For US customers, does the headlight switch need to be in the 'A' position, or is it off, and pathway lighting works?
Thanks,
Sam
JohanDC May 3, 2004 03:21 PM
If you want to have it activated automatically when you turn your car off, and this is currently not working, then pay your dealer a visit because this function needs to be activated in car memory too (=hookup to dealer computer & change the appropriate car memory setting).
