Passenger window won’t go down
My Ride: 523i
Hi guys. Sorry to bother with a small problem. Last night tried to open the window from passenger front side and nothing. If i try to open from the main switch from drivers controllers. No problem.
Ok did that. Opened the window from driver controllers lets say half way and after that pressed to go even lower from passenger controllers and it’s going up. Wtf? Hahaha.
Any suggestions? Found on internet loads of ‘passenger window won’t go up’ but not the other way around.
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
You say the driver's side window buttons and can make the passenger side window go up and down? If that's case, than all the internal lifting mechanisms in the passenger side door are working (e.g. window lifter drive, window guide, etc).
That could point to the passenger side up/down window lifter switch is malfunctioning?
My Ride: 523i
Yes sir. From driver. Perfect. Normal. Brilliant. From passenger just up. Like always up.
I mean I open the passenger’s window from driver and after that try to open even more from passenger switch(press down) and goes up lovely hahaha.
