Passenger Temperature
Old Oct 3, 2005 | 06:14 AM
derrickj's Avatar
My Ride: 2004 Silver Gray 545i, Sport, Navigation, Steptronic, PDC, Windowshade, Bluetooth Paired with Treo 650, Huper Optik tint, Euro reflectors, Poplar Wood Gear Shift, Poplar Wood Console Cover
When I have my A/C set on "auto" and my passenger changes HER temperature to a warmer setting, there is very little noticable change in the air temp. I have tested it by putting mine as cold as it will go and the passengers as warm as it will go and I still detect very little change in temperature. Is this normal? I am expecting one to blow cold and one to blow warm, but that is not the case.
Old Oct 3, 2005 | 06:24 AM
AC_S5's Avatar
Originally Posted by derrickj' date='Oct 3 2005, 10:14 PM
When I have my A/C set on "auto" and my passenger changes HER temperature to a warmer setting, there is very little noticable change in the air temp.? I have tested it by putting mine as cold as it will go and the passengers as warm as it will go and I still detect very little change in temperature.? Is this normal?? I am expecting one to blow cold and one to blow warm, but that is not the case.
[snapback]178502[/snapback]
What type of air (warm/cool) the A/C blows depends on the ambient temperature. If outside is warm than the car will not blow warm air unless you change the climate setting in your i drive to warm setting.
Old Oct 3, 2005 | 07:08 AM
JDN's Avatar
JDN
Hi, Derrick. I definitely had warm air coming out of the driver side yesterday and cooled air coming out of HER side. I only did for a minute or less, but my side was turned all the way to the right.
Old Oct 3, 2005 | 07:11 AM
derrickj's Avatar
[snapback]178525[/snapback]
Thanks, Jim! In that case, mine is obviously not working right. I did the opposite, but it didn't work (ie: mine turned all the way to left [cold] and hers all the way to the right [hot]) and while it decreased the force of the air coming out of her side, it still blew cold air, just not with the same intensity as my side.
Old Oct 3, 2005 | 07:18 AM
mr_djurgarden's Avatar
Have you checked out the air distribution menu? The output of the air is maybe turned to one of the lowest settings and that could be why you don't feel a difference. Good luck
Vman33
Mar 14, 2022 04:43 AM
BuddyB
Aug 17, 2017 12:48 AM
derooster
Sep 22, 2016 07:30 AM
Henry Peters
Sep 25, 2015 10:15 AM
cbdoya
Sep 15, 2015 06:09 AM
