Passenger side window
My Ride: '07 550i manual ground plane.
My passenger window doesn't go up with the button. It goes down but not up, when you press up it goes down instead. Any idea why this is happening guys? It works perfect with the driver side control but not with passenger side.
My Ride: BMW
I believe there is a way to re-initialize the windows. I could be wrong but vaguely recall the procedure. Put the key in the ignition and turn it on (I don't remember if the engine running or not matters). Hold the passenger window button down for exactly 17 seconds and then pull it up and hold it up. The window should go all the way up and back down. Again, do a search on initializing the windows.
Balbs
Balbs
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
Sounds like it might be a faulty switch. Just resetting if it fails then it is the switch.
My Ride: 2010 bmw 5 series sport edition
![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
I have a 2010 535i with75000 m . I suddenly got the passenger window not working . Also the front doors lock/unlock do not work neither by the remote not by central key . The mirrors are working perfectly . Interestingly , the rear doors and drivers window are working perfectly . I checked the fuses and found no issue .
any help ?
zio
06-18-2015 04:42 PM
