passenger seat restraint error message
I have the "passenger seat restraint" error. From most people with this problem have an issue with their passenger occupant weight sensor in the passenger seat.
However, when my daughter sits in the seat, the light above the rear view mirror goes out, which leads me to believe that this sensor is working properly. What else can cause the passenger seat restraint error?
Dean
Dean
My Ride: 2005 545
Leather shrinkage can cause the seat matt sensor to throw a malfunction .. Due to it being super sensitive .When the leather stiffens and shrinks it somehow tugs on the sensor and throws the error. But there is also other factors that will throw the same error on the idrive . But if indeed it is the passenger seat Matt and not module related like it was on my car , Condition the seat with Saddle soap mixed with leather conditioner worked into the leather several times fix the error . Since I did that the error has not came back . Got this information from a very reliable source and it solved my problem ..
My Ride: 2005 545
I don't think steam will be good for the leather ..
Saddle soap lathers up and has oils that penetrate deep into the leather when you put on numerous thick coats , thus making the leather soft and releasing the stiffness and loosens when worked into the leather . The matt sensor is attached to the underside with hugs rings . When the leather shrinks it contracts tight and pulls on the hug rings and trips the warning. From my understanding the matt sensor is really super sensitive .
Take a look in your manual and it should tell you exactly the behavior of this light. I know of a pre LCI a the light is supposed to be on unless someone is in the seat and of proper requirements. Mine is a 08 LCI and the light is NOT supposed to be on when no one is in seat. If someone or something is in the seat and the requirements are not met the light comes on. In the morning the light is out and when I come home from work the light is on. HA! At home car is garaged and at work it's outside so the sun heats up the interior. Coming home I can often reach over and massage the top seat cover a little and the light will go out. So just as H.F said, it most likely due to the leather shrinkage. Also, on our 2013 F10, the light is on unless someone is in the seat. So it's opposite of what my e60 is. Take a look and read carefully your manual just to make sure.
I appreciate the responses.
I've read recently that an under-charged battery will cause the error code, and disconnecting the battery could reset the code. I charged the battery and then disconnected it for ~30min's but to no avail. I have on order a seat pad sensor bypass gizmo from the UK for ~$40. Of course My state inspection is at the end of the month and I'll be risking a ticket/fine until the gizmo comes in. Still have to have the dealer erase the code.
I will certainly try softening the leather (It's overdue anyways). I'll be thrilled if it works.
I'll reply if I have any luck with this.
Thank you,
Dean
Thank you,
Dean
My Ride: 545i sport
FWIW: "Passenger" should not be taken literally to mean the non driver. "Passenger" can mean the driver as well. I received a "Passenger restraint" error on my '04 545i and the culprit was the driver side door module.
Can you clairify which light is on? You mention the above light and when your daughter sits in the car it goes out. This also sounds to me that it's working correctly on your 04. Now if you have the message in your iDrive screen, then for sure you have a fault. I can tell you for sure a dealer most likely will not reset your light unless they make the repair. There probably is some liabilty behind that. You might have luck with a Indy shop resting the light, but if there is a fault, it will illuminate again. Then you have to consider the reason for the light beingiluminated in the first place. There are a lot of different things that can cause an error. Some semi cheap and other very expensive to repair. Personally, I would want to know exactly why its on, or if the AB it will work at all if and when needed. You never know if that AB will be needed and the outcome of a crash if it doesn't deploy...
My Ride: 2005 545
Thank you,
Dean
Thank you,
Dean
That said ,,, what I did was got some saddle soap mixed with leather conditioner and lathered it up . Put on a thick coat 4 or 5 times for a couple days . Let the car sit for over a week .. Finally the error cleared after a couple attempts with BMWhat app.. Since then it has not came back .. Here is my thread on bimmerfest ,, it got a little heated for a bit . But some one posted a the actuall Matt sensor , once u see it how it's constructed . Also how it attaches to the seat with hug rings (that I found out ) it all makes sense .
http://www.bimmerfest.com/forums/sho...d.php?t=768831
By the way a seat belt error will not reset itself by disconnecting the battery ,, you need a code reader that can clear the code ..
My Ride: 2005 545
