passenger climate control problem
My Ride: Delivered 1/16/07 07 530i Silver Grey/Blk., ZSP, ZPP, ZCW, Logic 7, Step, Sirius
has anyone had problems with the passenger side climate? No matter what temp i set it to it always blows cool air. drivers side can be set via idrive but i cant get warm air to blow from passenger vents...Help me please its like 8 degrees here!!
My Ride: 2004 530 Steptronic, Nav, Std Audio w/ single CD, Premium Pkg, BMW Assist, non-working Bluetooth
Originally Posted by tom_hou' post='388017' date='Feb 6 2007, 11:25 AM
Passenger side air flow can be controlled from iDrive. Go to the Climate screen that shows the vent setup for the driver and push the iDrive to the right. Then you can set passenger airflow. Easier way to get to the screen is to press the voice entry buton and say "vent setttings". Hope this helps.
thanks but its the temp thats the problem....and there doesnt seem to be a way to change that in idrive...and when i change the temp on the dash it doesnt get warmer
I assume that the passenger's footwell vents work properly i.e. the passenger's side temp control on the facia works OK, and the problem is "only" with the face vents. If that's the case, then probably the actuator/servo managing air flow to the passenger's side is gone. Great fun to replace. If the whole passenger side temperature control is not working, then it's more likely to be the control unit. Less fun to replace, but more expensive part.
As a temporary solution, until you get your friendly dealer to look into this, I would physically close the face-level ventilation on the passenger's side before your passenger catches pneumonia...
Originally Posted by dlevi67' post='388031' date='Feb 6 2007, 12:08 PM
OK - first of all, the temperature you can set from the iDrive is only the (relative) adjustment for the face vents. And that is supposed to change all face vents, not just the driver's.
lol i was hopin not to take it in to the dealer...i only have 130 miles on it...but i guess i have no choice...oh well my first trip of many to the dealer based on the feedback ive read here in the forums.. thanks again
My Ride: 2006 525i Silver Gray/Gray Dakota Leather | Steptronic | Cold Weather | Xenon | Premium Package
Modifications:
M Aero Kit | Carbon Fiber Kidney Grill | K&N Air Filter | Charcoal Filter Removed | Radenergie R10 Silver 20" soon | kW coilover V3 | SprintBooster soon | M5 trunk finisher
Next planned mods:
?Hamann quad exhaust + Hamann quad rear diffuser + Hamann Front Lip?
You might need to take it to the dealer. I think that's for the best. I've had problems with my i-drive too. Right now, my i-drive tells me that there's malfunction with the driver airbags, and the passanger restraint system. I have no idea what that is, and I went to the dealer to have them reset it.
nor automatic nor manual.
At the first service last week I got the new 24.2 CIP.
It didn't work after the service either but the next day everything
started to funcion and has work fine after that
My Ride: E60 530dA 3/2004
Originally Posted by Ricracing' post='388043' date='Feb 6 2007, 12:33 PM
I had a problem with the fan, it didn't react to any changes
What was similar in those cases? Yes! horrible coldness (You know what I mean :'( ) and short sycle driving. E39 has a voltage control system in several places to protect battery not going too empty. but it retains current very (too?) easily. I guess that in E60 the same system is more clever. It controls voltages and switch on/off depending availability of power a bit longer periods.
Originally Posted by jaki' post='388054' date='Feb 6 2007, 05:52 PM
I had a similar experience, and also seat heaters didnt work for about five kilometres. first last november with my previous E60 and yesterday with my newer one.
