Passenger airbag off
#21
CAS is the Car Access System
I believe the OC3 is the seat mat sensor itself and the SBE is the control unit and I don't think you have either as you have a CAS. I have a 2004. I know mine works as intended. BMW always changes control modules and their functions so you may have something that works different from mine.
FOR ME: IT ILLUMINATES ONLY WHEN NO PASSENGER IS DETECTED.
However, for you it may be different and I'm sure it is because your illumination is different than mine. Also remember reading about someone being able to turn off their airbag with their key for child occupancy. I think it was EU model...never checked mine for this feature.
Good luck
Good luck
#22
Good luck
Good luck
#23
My Ride: BMW 525dA 2007 pre-LCI.
yes, as far as i know the E60 in the EU has an option to turn of the Airbag with a key. Most other brands here have this standard but on a BMW this offcourse is an option. Likewise for Cupholders
#24
I know the E60 in Eurpope allows you turn on/off aibag. I haven't checked my E60, E46 or E85 to be quite honest. Never even looked at the owner's manuals for any of them!
LOL
![](https://5series.net/forums/public/style_emoticons/default/wacko.gif)
#25
I'm sure you don't. I know the E85 IP has to base substrates. Actually mold difference and not just water jet cuts. The ECE would not come with the knee airbags like the US has. Well, unless you went over to Europe and bought one and then had it sent back here.
#26
No i actually have the button. I don't know if it was imported from EU or built here in states but it definitely has the passenger airbag on/off
#27
Hey Achtung, I mis-spoke about your E85. I went back through my notes and the airbag switch on the pasenger side of your IP was 100% in US and not required for most other countries. Also, the US will have a knee airbag under the steering column, ECE does not, they only have a knee bolster. So if you have the knee airbag, then you have a US IP.
Vman33
03-14-2022 04:43 AM
