Hi, had two snapped studs when I removed the valve cover. Turned out they are called standoffs or stud extensions. Par is not listed anywhere.... Anybody else had this unfortunate issue before?
Thanks, but no good. It's for the injectors. Got the standoffs from the scrapyard but now I need to rethread the holes as screw extractor doesn't work well. If there is anybody else with the same issue I would suggest to remove them with the cover for the timing chain, they do snap...
