I'm trying to get my '05 545 to vent the cabin using the Parked Car Operations "Vent" feature. I set the two timers for different times and activate they by checking the box above the time. I then exit the menu and confirm that the Red fan indicator under the fan speed control knob is lighted. But the car does not run the fan at the set time. I've set both timers (I cannot determine if the time I have set is 5PM or 5AM) and have not had either one work. Has anyone used this, or maybe better had this not work, and then fixed it? Any help would be appreciated, thanks...
I used it before and it worked. but dont really use it anymore. *shrugs*
I would suggest unchecking it and leaving it off for a day and then try setting it and enabling it again. Sometimes software just needs a reboot. Click it off and click it on again... but leaving it unchecked overnight would just ensure that the car goes to sleep with the feature off and when you check it back on it'll be "fresh" |
5 am or 5 pm - I have my clock set for military time (24 hour clock) so I don't have this problem.
It has always worked for me - the fan graphic blinks red until the fan starts and then shows steady red. You should be able to hear the fan motor running. Also the air is coming out the windshield defrost vent and not the AC vents. |
Ya you can hear it... its fairly loud and you can totally feel the air blowing.
Originally Posted by top6491' post='585178' date='May 21 2008, 09:32 AM
Thanks, that's different fomr mine. My fan graphic stays solid red as soon I set it and never blinks.
Originally Posted by GT Premi' post='585318' date='May 21 2008, 10:24 AM
So does mine. But my system works. You're probably setting it for the wrong times. Why can't you tell whether it's AM or PM? :huh:
I use mine all the time. I set Timer1 for about 15 mins before I plan to leave work and sure enough it works everytime. Could it be related to a "low" battery condition and the computer won't allow it to activate?
