painting Calipers.. need some info!!
hi everyone.
I am planning on painting my calipers with the G2 paint system. + put the BMW caliper decals on them.
now.. here comes the challenge, have any one of you painted the calipers one wheel at a time, without having the paint getting hardened, considering you'd have to lift your car, remove the wheels and prep the area and then paint it at all 4 wheels and also put the wheels back on. The paint is sort of epoxy paint.. once u mix it with the activator then it starts to go cure when u paint them.
Any insight on this would help. Thanks in advance.
I haven't painted mine yet, but will do in the near future. Not knowing exactly what kind of paint that you are using, but you mentioned it's a 2k so I would suggest that you find a way to prep all four brake calipers and paint them during the same time. Or, you could mix a small amount then prep and paint each one individually. Perhaps on the label somewhere it will tell you what your working time of the mixed paint is. Otherwise, I would guess about 30 minutes maximum and depending on outside temperature this could be a little more or less. Good luck and post back with pics when you are finished!
with the G2, you should prep all the calipers first and then paint them all at the same time as the paint will harden about. working time is 1-2 hours after mixing but after about an hour it starts to really thicken. you will also need the whole can for multiple coats on all 4 calipers & brackets. and make sure you don't drive the car for a day after painting for proper curing. i did mine with around 60k on my car and there was so much brake dust that was caked on that i actually had to use a cookie sanding disk to clean all the parts. let's just say there was dust everywhere. but a year later now there are no chips anywhere and the paint looks flawless. remember prepping is the most important part!
hmmm.. if u remove all wheels at once, how does the car stand? because i was thinking of removing one wheel at a time.. i guess. i'd need a separate container and mix the paint and activator for individual wheels, instead of using up the whole container. And so if it cures, then do you just stick on the caliper decals?
You might want to invest in two sets of jack stands...
My Ride: 2007 525i Premium Package "All Black Everything"
EXT: 20% Tint All Round | M-Front (Weezy) | Black/White Roundels | Shadowline Paint Match Grilles | M Style Sidemarkers | Vertini Riviera-S 20s
INT: I POD Intg | Trim Rings | ACS Pedals | Cobra XRS 10G
LHT: Xenon Adaptive | XENESIS Fogs| WeissLicht Plate LEDS | Door LEDS I Interior Xenon Pkg
PER: RPI Induction (Weezy) | BMC Filter | Sprint Booster V2
AUD: JL Audio
i just did my fronts with the help of ENJOY last weekend. got to go for black looks killer and no more ugly rust
+1 on all of the above comments.
Preparing the surface is THE MOST important step for ANY paint job. Jack stands is the way to go - prep all 4 calipers, mix the paint, then carefully and quickly apply the paint on all 4 calipers.
Any of you have pictures of BMW 5 with calipers painted black?
Get yourself a wire wheel drill attachment and a wire brush. Clean all parts with brake cleaner. You can do two wheels at a time with multiple coats. Jackstands also help. Also, remove the caliper clips (rusted part of caliper) and paint them individually.
My Ride: 2006 5 Series ????
I did mine last week !! Did one side at a time (space restriction) so I used 2-G2 kits.
_Cut 2 wire coat hangers to make 4-hangers to hang the calipers (unless you're gonna remove them from the car)
_Get an extra can of brake cleaner cause what's included will not be enough. (if you're using one kit)
_Use an oil drain pan to catch debri as you clean calipers.
_Need old toothbrush
_Small paint brush. (the foam one they give you makes the job so much harder)
1). Jack up car, remove all wheels and set on jack stands.
2). Use brake cleaner included with kit. Put oil drain pan under caliper and clean as much
as you can using the toothbrush & rags before removing the calipers. Then remove clips, calipers &
Brackets and finish cleaning....
3). Mix hardener with paint, stir very good.
4). Now hit the brackets & clips with one coat and move to the calipers. Then come back to the brackets
for a 2nd coat, then back to the calipers to finish up. All the time stir the paint to keep it from
hardening so fast.
You have a 4 hr window so keep going til complete. "Wolla"
I also touched up the rotor hub & edges along with the backing plates (while it's all broke down)
Suggestion: While you're doin this, if you don't have already, I suggest
installing Ceramic brake pads. They bite well and give off VERY LIL dust.
hardening so fast.
