Overheating !!!!!
My Ride: Carbon black 530 sim full. Carbon kit
Overheating !!!!!
I have a strange problem ...I have an e60 523i but with a z4 si m engine in it it also has full custom induction system and full custom exhaust system it has had a custom tune done on the ecu an it's fantastic........until yesterday when it started to over heat...I thought it a bit strange because it's never happened so I let it ool down topped up the Levels and drove it home, hen I got home I noticed that the heater was not getting hot so I did the following checks
Checked levels all here fine
Checked hose temps ..,top of radiator was lava hot and bottom was cold
Took top off expansion tank with engine running and I could see constant movement of coolant ....so I guess the pumps working
So I'm stuck ...what could it be!
My Ride: 530i
Engine: M54
good luck with the car.
