Original alloys vs. replicas
Old 11-19-2008, 08:05 AM
Dr Dave's Avatar
the problem with a lot of these asian countries is there electrical supply
when they are welding, they get power fluctuations that result in "weak welds" not noticiable but under loads they can fail, beleive me i know as i race subarus and the products from china/taiwan are no where as strong as europe/north america
FACT.
Old 11-19-2008, 08:29 AM
AKAlius's Avatar
get some miro's rims. heard only good stuff about them.
Old 11-20-2008, 12:09 AM
delje08's Avatar
My Ride: 545i
replicas will give you headaches if you buy the wrong ones. vibration vibration vibration.
Old 11-20-2008, 12:36 AM
deocool's Avatar
Can you suggest the 'right' ones then, would appreciate
Old 11-20-2008, 12:39 AM
Speed_Force_E60's Avatar
Get Miro Replicas... they are the "right" replicas
Old 11-20-2008, 12:45 AM
the chang's Avatar
Look around for some used OEM wheels - that's what I did. I think I got my 172s for around $1300 with tires. Definitely go OEM with wheels.
Old 11-20-2008, 01:04 AM
deocool's Avatar
thanks, you i've heard this brand mentioned a couple of times, should be good then , i guess
Old 11-20-2008, 01:51 AM
deocool's Avatar
i guess there should be some marks or signs on BMW original rims indicating there origin, are there any?
Old 11-20-2008, 02:27 AM
stavros's Avatar
My Ride: 2004 BMW 545i, M-Sport Bodykit, Sports Suspension, Sports Seats, Active Steering.
+1. Don't sacrifice quality to save a few bucks, you will regret it.
Old 11-20-2008, 05:52 AM
billhk's Avatar
My Ride: carbonized MB coupe
i had replica 18 inch "taiwan" AC type IV racing alloys before, they vibrated a bit above 80kmh and did not come with the proper spacers eg.only thin rings of aluminium, and therefore there was a very small gap.
It is hard to tell if it was really made in Taiwan or the PRC.(some oem 122 spyders are made in PRC so not all PRC is rubbish!)
On the other hand, Pingy has a set (but wide rims) and they have been ok.
My wheel guy did not recommend fitting bigger then 18' replicas on a E60, he said it was dangerous as they may crack(showing me a cracked rim)on a big car!!
i now have original German made 19' breyton race cs, they came with snug fitting spacers and long screws, the ride and
stability and control is perfect, it's easily the best mod I have done, this is the part of the car in contact with the road surface, so only select the best to get the best ride and control.
think it over, 1000bucks more and you get the real deal
Quick Reply: Original alloys vs. replicas
