One more reason I hate the runflats
Old Aug 17, 2008 | 09:58 PM
studavis's Avatar
My Ride: 07 550 i, mystic blue, black leather, cold weather package, nav, sport, shades, bags, rear heat, V1 hardwired. 05 F350 TD Crew Cab 04 Range Rover HSE 91 964 C4 Cabrio 07 997 Turbo Cabrio
Although the tires were complimentary, thanks to this forum, I have discovered one more reason to loathe the run flats. This image was taken of my garage floor, and you can clearly make out the image of the tread pattern of the tires on my epoxy finished floor. I tried to pressure wash them, tried using a few solvents, and nothing seems to work. I am assuming that the brown residue is some sort of protecting film applied at the tire at the factory, but I don?t want to wait six days for my SA to call me back and confirm my own suspicion. Seriously, can anyone make a defendable argument as to one single redeeming feature these tires have? The run flats should be a debate topic next year for the national debating scholarship.
Old Aug 17, 2008 | 10:02 PM
EBMCS03's Avatar
If thats the case it wouldnt only pertain to runflats any other tires would have the same "protecting" coating.
Old Aug 17, 2008 | 11:17 PM
Lancaster's Avatar
My Ride: 520d Black & SL350
Originally Posted by studavis' post='648916' date='Aug 18 2008, 06:58 AM
<SNIP>
When you have a puncture, you don't have to stop at the side of the road to change a wheel.
Do I win the debate?
Old Aug 18, 2008 | 05:57 AM
Dandle's Avatar
My Ride: 07 E61 530d M-Sport.
I would say thats a problem with the flooring not the tyre. If its garage flooring then it should be able to withstand oils etc and that mark is only from a tyre resting on it.
Old Aug 18, 2008 | 06:03 AM
Howitzer's Avatar
exactly.
Old Aug 18, 2008 | 06:04 AM
CWS530's Avatar
It appears to me that after enough wear, you have exposed the fossilized remains of a coelacanth. You may want to alert a local university. Such a discovery could rock the evolutionary science community.
Old Aug 18, 2008 | 06:31 AM
HotLap's Avatar
My Ride: 2008 535i, 6spd mtx, Monaco Blue w/Beige interior. Sport, Preimum, Logic 7/HD/I-Pod/USB, Nav sys, rear sunshade, HUD, PDC, Split seats,
I'd be curious to see if Meguier's Cleaner/Wax would take that off? Worth a try at least?
Old Aug 18, 2008 | 10:57 AM
GoRovers's Avatar
Originally Posted by Lancaster' post='648940' date='Aug 18 2008, 12:17 AM
When you have a puncture, you don't have to stop at the side of the road to change a wheel. Do I win the debate?
I love my RFTs. Not just because of Lancaster's correct mentioning of security and safety, but also because RFTs have more rigid sidewalls, which positively affect aggressive cornering. Granted, the ride is not the smoothest, but over time the bugs will be minimized and all tires on all cars will be RFTs. They just make sense...
Old Aug 18, 2008 | 11:49 AM
stiker's Avatar
My Ride: 535d M Sport / Carbon Black Metallic / Aluminium cube / black leather sports seats / Prof. SatNav / Bluetooth.
Runflats will take over the world one day...
When they have worked out how to build them to avoid the harsh ride, 'skipping' under hard cornering and hideous noise
Butr not yet :thumbsdown:
Old Aug 18, 2008 | 02:32 PM
studavis's Avatar
It is not the floor covering, as the the other car's tires would do it. The epoxy on the floor is a military grade high zoot spec stuff that I used in my hanger, so I know it is impervious to to just about everything but Dunlop runflat tire juice. I am going to try a little hydroclorich acid on it next, that should do the trick. No, you don't win the prize for a puncture that you can drive on, because we have 24/7 roadside assistance, and if you have a flat, you change the tire from the spare in the trunk, and get the main tire fixed. Runflats are an exspensive way of driving a short distance to get a new tire. I just don't see the logic for putting them on the car in the first place, and having the tire goo staining the floor was just one more reason to hate these things... Venting just about done....
