Okay I got a weird problem...
My Ride: 2004 545i 6 speed, Silver Gray A08, Gray leather
Mods: Hard-Wired Passport 9500ix LIVE , K&N Air + RPi Scoop, Mtech V2.1 AE, ACS pedals+Ebrake, flip up front plate, OEM 172's, Custom M Kit, M3 shift knob, Eisemann Race Exhaust
2005 X5 3.0 (the nightmare)
1998 528i SOLD @ 173K
Last night drove the car to dinner everything was fine. Left dinner car started just fine then I get the active steering and dynamic drive error. Drove home parked in driveway overnight. This morning car is dead.. test the battery and its at 6.4 volts ouch. Pull the battery out give it a charge its dated Jun 08 take it to pepboys they do a test and it checked out 857cca battery spec is 850. Bring it home put back in car starts test the charging system jumps around from 13.8-13.9. Just took a drive and it seems like the car is chugging when at a constant speed ie 35 mph in 3rd gear. Pulled up to a stop light and my rpms are staying at or close to 1000. So im kinda confused anyone have any problems like this?
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
Sounds like the alternator to me also. Get it replaced before your alternator dies completely and the car draws its electrical power needs from the battery which in turn will die also. Happenend to me about a year ago.
Don't know why it could be the alternator when you have 13.8-13.9 volts at the battery when the car is running. With that kind of voltage it is obvious that the alternator is putting out. Since you had the battery out of the car I would think that the car needs to be driven for a short period of time so that it figures out what it is doing again. My biggest ? would be why the battery was at 6.4 volts, either something stayed on overnight and dragged the battery down or the battery is bad (regardless of what Pepboys said..like they have a clue anyway).
alienintelligence
09-07-2015 12:09 AM
