Ok rear jacking point? Pics attached
Is it ok to jack the rear of the car up using this location in order to get jack stands under jacking points and/or blocks under rear wheels?
Thanks in advance,
Dave
Thanks in advance,
Dave
My Ride: 535xi 2010
Model Year: 2010
For the rear of the car I've used the bottom of the differential, the jacking point in front of the back wheel and the bottom of the rear arm that connects to the wheel. All three worked fine.
My jack hits fins on differential cover so I would need to fabricate up a block. When referring to the rear arm that connects to wheels, I assume your talking same place as in my pics?
I would avoid the suspension parts as they are usually aluminum and easily bent.
