oil service gauge
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
Okay BMW changed my oil for me before the warrenty ran out and before the clock ran out about 1000 miles before, now here in lies the problem service light came on but you can not reset it yourself even with idrive. That is just stupid to have to make a trip to the dealer after warrenty has run out just to get the indicator reset. I can reset the inspection, brakes, micro filter and a couple of other things.
Why are they BMW still following this old pratice I drive is new utilize it darn. My other 5 car e34 I had to purchase a reset tool I guess I will have to do the same thing again when one comes out.
My Ride: Mini Cooper
I have the tool too.
they just what to get money out of you after the warrenty runs out.
Engine: 530i
I have the peak research tool that fits the adaptor under the hood, I do not see the same type of fitting on the e60 whenever I have something done they put the equipment on th foot well on the drivers side link us to the tool that you have
Originally Posted by Ceenit' post='514697' date='Jan 7 2008, 10:24 PM
can you provide a link to an example of the tool?
Thanks
Thanks
take a photo of the plug from your car and ask him if itwill fit.
if your car is 2004 like my then it should work.
![oil service gauge-reset_tool.jpg](https://5series.net/forums/attachments/e60-discussion-2/42624d1482365766t-oil-service-gauge-reset_tool.jpg)
http://cgi.ebay.com/ebaymotors/BMW-RANGE-S...bayphotohosting
Engine: 530i
thanks ordered one sould be here by Monday
Engine: 530i
Originally Posted by pinguhk' post='514927' date='Jan 7 2008, 11:12 PM
ask the seller if it will work on your car.
Attachment 42624
Attachment 42624
What I did that has not worked yet is opened the footwell cap
inserted the ob2
it lit up
I then pressed the oil button and it started flickering red yellow green
waited for a min but did not reset oil
So I then repeated the procedure with the key in the on (start position) followed the above proceedure
same lights but did not reset the gauge
Am I not waiting long enough or am I simply doing the steps incorrectly? I will search the net for a procedure also but thanks in advance
My Ride: Estoril Blue 440i GC
Model Year: 2017
Guys,
Do a search on the forum for service reset - you don't need a tool to do the job, just a bit of patience.
Mike
Mike
http://forums.e60.net/index.php?showtopic=17756
Hopefully this should work.
Originally Posted by Kev525' post='193584' date='Nov 4 2005, 05:16 PM
Please do post the steps that you did to reset the servcie indicator. I tried it according to the instructions in this post but not successfully. ![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
Right, I'll try and explain in detail what I did and what I saw when I was doing the Brake Fluid reset. Forgive me if the instructions seem patronising in any way but here goes:
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost".
It took me a while to get the hang of it and I'm sure it'll take me a while to get my head around it again next time.
Let me know how you get on.
Hints & Tips
Engine: 530i
thanks I did do a search but I guess my keyword was wrong. I will try this procedure if I can get my 30.00 dollar tool to work thanks again for the tutorial
