5Series.net - Forums
-   -   Oil pan gasket replacement (https://5series.net/forums/e60-discussion-2/oil-pan-gasket-replacement-154376/)
fast Mar 30, 2025 12:10 PM
So is there anything else I need to do while the subframe is down, like the motor mounts etc
The car is 2007 with 70K miles
Thanks
seanjordan20 Mar 30, 2025 12:17 PM
Definitely the motor mounts since frame is down. You can still install without it down but easier with it down.
fast May 2, 2025 06:16 PM
So it all started with a slight engine leak, thought it was Valve cover--- replaced but the leak continued so ended up replacing the oil pan gasket/motor mounts/hood shocks/new spark plugs --- all done
Needs new tires now and good for a while-- IA
seanjordan20 May 3, 2025 01:01 AM
That's great you got it all done. You probably should change your name to slow because you took your time with the project. 😂 j/k Glad everything's done. I need to do mine but I'll get rid of it before I drop mine again.
