tv_5series |
01-22-2019 02:59 PM |
Oil Level Sensor acting erraticly
I bought my 2007 530xi with 85000 miles on it a week ago and drove it from Chicago to Maine. everything worked perfectly until 3 days ago I got a message saying 'oil at minimum - add 1 qt' so I added a quart of oil and bought enough oil to store a few quarts in the trunk and also to do an oil change. The next morning I started the car, let it warm up in the driveway and checked the oil in the iDrive system and it said 'oil level OK' and showed it was just 1/4th above the low indicator. I started driving and 15 minutes later I got the alert that the oil was at minimum and to add a quart, so I added another quart when I arrived at work, the same thing happened on the way home so I added another quart.... last night I decided that I should drain the oil and see how much oil i'm missing and make sure it wasn't leaking from the drain plug. I removed the drain plug and not only did the 7 quarts the engine is supposed to have come out the additional 3 quarts of oil i added came out and made a huge mess on my garage floor (my oil drain pan only holds 7qts) so I changed the filter and added 7 quarts of oil.
This morning pulled out of the garage, made sure there was no oil on the floor, let the car warm up and verified the oil level was good in the iDrive system. Again I drove 15 minutes and I got a new message that my oil is below the minimum level, (it never even went from ok to minimum, just straight to below) and damage may occur, I carefully brought it back to my house. later in the afternoon I started the car and checked the iDrive and surprise... the oil level reported it was OK. I suspect that the oil level is fine and its just the oil level sensor (I have read they have problems in cold climates like here in Maine) but oil in an engine is not something I take chances with. If anyone has any ideas or can confirm this is the oil level sensor when its close to failure id really appreciate it as i'm stressing over a car I've owned for exactly a week wondering if I've made a terrible mistake.
