Oil Level Sensor
Old Feb 29, 2016 | 01:13 AM
kskane's Avatar
My Ride: E60 M54
Model Year: 525i 2004
Default Oil Level Sensor
Hi Guys, I got 27C3 Thermal oil-level sensor = P1128 error code, so I believe the oil level sensor is out as I did not got any warning and on oil drain got only 4L out of my 6.5L capacity M54.
Now, while attempting to replace the oil level sensor, should I also replace the oil pressure switch + Oil temprature sensor? Do these two sensors go bad?
Old Feb 29, 2016 | 04:32 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
The temp sensor/pressure switch rarely goes bad but for $10-$30 why not. It is really up to you. Being that thy have not failed you do not need to change them.
Temp sensor
Temp sensor
Old Feb 29, 2016 | 04:45 AM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
Oil temperature sensor is integrated into the oil level sensor on the m54.
Old Feb 29, 2016 | 04:28 PM
I failed to read the oil part of the phrase. I gave the temp sensor in the DME.
Chris Karolenko
Oct 26, 2015 12:56 PM
Chris Karolenko
Oct 23, 2015 12:50 PM
rmistry22
F10 Discussion
Jul 24, 2015 05:35 AM
rvnmaniak
E60 M5 Discussion
Jun 21, 2015 02:21 PM
Bedford530i
Nov 12, 2004 07:37 AM
