oil leak 545i
Old 12-16-2009, 06:28 PM
jprovence's Avatar
I haven't got e erything back together. The weather has been pretty bad. The print was not damaged. It had just worn out from being compressed and heat cycled. I should have everything back together by the end of the week. I would go ahead and get the ring on order you realy have very little to lose.
Old 12-16-2009, 07:32 PM
saf545's Avatar
Omg here we go again. My 45 has been leaking all over. Darn it.
Old 12-31-2009, 07:17 AM
dbond698's Avatar
Any luck with the reassembly and outcome with the leak?
Old 12-31-2009, 03:10 PM
jprovence's Avatar
I replaced the ring, it seems to be leaking from the front housing cover on the pump. My next step is to remove the cover and reseal. If that fails, (ie, I can't get it back together) then I will buy a new pump. About $350
user 4639202
09-23-2021 09:07 PM
demosthenesish
05-01-2015 06:02 AM
545iBMW
04-28-2015 03:24 AM
cointilt
03-30-2015 10:50 AM
andrek
03-26-2015 08:00 AM
Quick Reply: oil leak 545i
