Oil leak :(
My Ride: 05 545 BLK/BLK
Model Year: 2005
Woke up the other morning to oil droppings on the floor of my garage... I didn't have a low oil warning light though. But I took it to my indy shop and got a call saying my Valve Cover Gaskets need to be changed!! How bad is this? I'm going to have him change my plugs as well, and roughly we are talking $1300. Good, or bad?
BTW.. I have a 05 545.. with 106K miles on it.
Thanks in advance.
Thanks in advance.
The valve cover gaskets shouldn't be leaking that bad enough where you see it on the floor. The alternator gasket, however, can become a serious leak once it starts. Here are things to look for
Upper timing chain cover (both left and right banks)
Alternator bracket gasket (Behind the alternator bracket and must lift the engine to replace)
Valve cover gaskets (Not easy to do as the valve covers are NOT easy to remove)
Vanos O-Rings (Two on each bank and they are just rubber seals)
I've DIY'd all of these with the help of a couple very skilled members here. The biggest PITA is the bracket gasket. Kinda wish you were in SoCal. PM member HealthServices for advice. He's the MAN.
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
I am going to fix all these oil leaks but was wondering if I have to replace the engine mounts also once the engine is lifted? As I see they are hydraulic and not cheep. Do they get bad? I do not feel any shake of engine at this time.
Specific to N62B44 engine (545i). It covers the hole left when BMW removed the oil cooler. Same engine on 745i used the oil cooler but they left it off the 545i. Lack of space, cost, who knows? But it was a criminally stupid thing to do because it ends up leaking on every 545i eventually.
