Oil Filter Housing Leak Repair - Anything else should be done while in there?
My Ride: 2006 E60 550i
Hey everyone. I have an 09 528i that is getting the infamous oil filter housing leak addressed soon. While the intake manifold is off when they're changing the oil filter housing gaskets, is there anything else I should replace while they're in there?
The additional jobs they are so far going to do:
- oil change
- coolant change
- front upper radiator hose to thermostat
- aux belt
- intake manifold gaskets
Here's a list of parts I'm providing for this job so far. Should I include anything else?
Alternator Bolt Set (Aluminum),
Brand: Genuine BMW
Part #: 12-31-0-392-568-BOE
Gasket - Engine Oil Cooler to Oil Filter Housing,
Brand: Genuine BMW
Part #: 11-42-8-637-820-BOE
Engine Oil Drain Plug (12 X 1.5 X 16 mm)
Brand: Genuine BMW and MINI Note: (2009 BMW 528i Base Sedan)
Part #: 11-13-7-535-106-BOE
Copper Washer - 12 X 17 X 1.5 mm - Oil Pan Drain Plug
Brand: Genuine BMW (2009 BMW 528i Base Sedan)
Part #: 07-11-9-963-151-BOE
Water Hose O-Ring for Thermostat Hose (29 X 2.9 mm),
Brand: Genuine BMW
Part #: 11-53-7-545-278-BOE
Radiator Hose - Radiator to Thermostat Housing (Upper) (Automatic Transmission Only) -
Brand: Genuine BMW
Part #: 17-12-7-546-064-M9
Oil Filter Housing Bolt (Upper)
Brand: Genuine BMW
Part #: 11-42-7-540-758-M9
Oil Filter Housing Bolt - 8 X 43 mm (Rear Lower)
Brand: Genuine BMW
Part #: 11-42-7-540-763-M9
Oil Filter Housing Bolt - 8 X 28 mm (Front Lower)
Brand: Genuine BMW
Part #: 11-42-7-540-759-M9
Gasket - Oil Filter Housing To Block
Brand: Genuine BMW Note: (2009 BMW 528i Base Sedan)
Part #: 11-42-8-637-821-BOE
Gasket Set - Intake Manifold to Cylinder Head
Part #: 11-61-7-547-242-BOE
- oil change
- coolant change
- aux belt
Brand: Genuine BMW
Brand: Genuine BMW
Brand: Genuine BMW
Brand: Genuine BMW
Brand: Genuine BMW
Brand: Genuine BMW
Brand: Genuine BMW
My Ride: 2008 535xi
Engine: n54
Well I have an N54 so it's a little different.. but one year after I replaced that, I had a leaky valve cover gasket.. had I known I would have gotten any of that done when I did the walnut blasting or even that oil gasket. ...
My Ride: 2006 525xi
Hello, just had my oil housing gasket replaced last week, amongst other items, $$$(06 525xi) if your cooler sits with your oil housing I recommend replacing the cooler gasket while it is off. My Indy replaced my serpentine belt as well it is recommned to replace idler pully and tensioner assembly when replacing belt. Check your transmission pan (plastic) if you can, he replaced mine had a leak, glad I found him he is excellent. Good luck!!!
My Ride: 536xi Sport Wagon - 2008 1200GS Moto
Engine: N54
2008 535xi E61 Oil filter housing gasket. Update
I'm in the painful process of having the oil filter housing replaced ($800) after it leaked on the serpentine belt requiring it's replacement($500). I note that OEM parts are mentioned here and I'm wondering if there really is a difference between them and after market parts except an incredible price difference. I was told that Victor gaskets are know to fail. Suggestions? Klinger or Ajusa?
My Ride: 525i
Model Year: 2005
Engine: M54
