Oil Consumption
My Ride: 2006 530i Jet Black over Beige Dakota Leather/Premium pkg/Cold Weather pkg/Steptronic/Xenons/Folding rear seats w/ Ski bag
Retired- 1973 2002 Inka Orange over Black/Dual Weber 40 DCOE Side Draft Carbs/Ansa Exhaust/VDO Gauges
I just noticed that after less than 3,000 miles my electronic dipstick reading has dropped one bar. Cause for concern? Should I expect some consumption? No leaks are evident. Car has less than 40,000 miles. Any comments or observations are appreciated.
Just had issue with this. Had to fill car with full qt. of synthetic after about 4k miles of driving. Totally normal. If you're burning more than 1 qt per 750 miles of driving that is a serious issue. If no apparent leaks, you're ok.
The car usually needs an extra quart after 3k miles.
In your case, with 40k miles, you are probably fine, but keep an eye out.
Perhaps you were already on the line, and you just lost some ounces that put you over by a bit.
Usually, at 40k miles, you should not be losing oil.
Put more in and see if it drops again.
My Ride: 2007 Mercedes Benz e63 AMG
My car often needs a quart of oil. In fact, its twice gotten to the point where the warning about low oil level has come on.
At first I was worried, then I realzied "what the hell, its a lease" and quit worrying about it.
I do drive the car very agressively, so that must have a lot to do with it.
Thanks- that puts me a little more at ease.
Vman33
Mar 14, 2022 04:43 AM
bestofthebest
Mar 28, 2016 02:47 PM
