Oil Change Suggestions
My Ride: BMW 5'er 520
Hi All,
I want to changed my gearbox oil and filter, so I am a bit lost now what oil I should be using as I found one on ebay 10 Liter ATF Getriebe Öl für SHELL M-1375.4/ Automatik Getriebeöl - 10 Liter ATF Getriebe Öl für SHELL M-1375.4/ Automatik Getriebeöl | eBay
just curious will this oil fit my gearbox?
BMW 5'er E60, Automatic/Triptronic, 2004, 520i.
Many Thanks
Many Thanks
My Ride: E60 M54
Model Year: 525i 2004
Hi All,
Many Thanks
Many Thanks
Oil grade standard is SHELL M-1375.4 which you have got right. Change the oil and filer every 40K's, I would recommend ZF lifegaurd 6 or Liqui Moly Top Tec 1800 oil.
My Ride: BMW 550i
Hi All,
Many Thanks
Many Thanks
it is not SHELL oil it is SHELL specs oil called MANNOL. what is putting me off is price 48 EURO for 10 Liters??? I would choose better oil while you are trying to save on oil you can endup rebuilding complete gearbox
Well I just cannot find the perfect oil during my search on Ebay for Shell oil it gives me Dexron, I think I might just jump in to car dealer and ask them about gearbox oil prices as I want soon to change filter and oil. Used Dextron oil before and I don't think its a good oil to use.
Here is another offer found on Ebay in GB which includes oil and filter together, BMW 5SER E60 E61 AUTOMATIC GEARBOX TRANSMISSION SUMP & ATF MEYLE | eBay As I see it offers MEYLE LIFE GUARD 6 do you think that is any good ?
My Ride: BMW 550i
just buy oem oil unless you want to save some $$$
ZF Lifeguard 6 / M 1375.4 Transmission Fluid 1 x 5 ltr | eBay
or this one
ZF Lifeguard 6 Transmission Fluid. 1 Litre. Land Rover, BMW, Jag, Shell M-1375.4 | eBay
Thanks bmwrider2010 I think Ill order that ZF as it seems to be the most recommended oil from all research that I have made.
Many Thanks
Many Thanks
How much oil would you recommend I should buy? I think there are all together 10 litres, where some of it will stay inside the gearbox not all oil is coming out, not sure how much oil I need to order any suggestions?
My Ride: 2006 BMW 530I
Model Year: 530i
Check these out:
BMW Automatic Transmission Oil Pan Filter Gasket Drain Plug ZF 217 | eBay
https://5series.net/forums/private-m...-fluid-129883/
http://www.ebay.com/itm/200720631642...84.m1439.l2649
