The Official G-Meter Testing Thread
#231
Originally Posted by grogan545' post='245844' date='Feb 25 2006, 09:08 AM
I am waiting for your new results.
Below are your corrected values. You can easily infer your correction factors from them using your raw data.
Runs on 2/20/06:
Corrected ET: 13.581
Corrected MPH: 102.815
Density Altitude: -1718.1 (feet)
New run/new site:
Corrected ET 13.712
Corrected MPH 103.807
Density Altitude: -1492.6 (feet)
#232
Originally Posted by Znod' post='246227' date='Feb 26 2006, 06:39 AM
Thank you for your interest Eric. Well, I can say at least that I have used my car to its fullest extent a significant number of times since 20.01.00. My car started learning, but then seemed to cease after 20.01.00. I decided that the problem might be my minimal mods and had them removed. The car quickly started learning again and soon moved beyond its mods-on level under 20.01.00. It appears to have had another recent learning spurt. And, I am producing some very good test results now. I think that's it in a nut shell. Let me know if I can provide more info.
grogan545's car immediately took a liking to 20.01.00. And, its performance seems better after than before.
What minimal mods did you have?
#233
#234
Originally Posted by Znod' post='246329' date='Feb 26 2006, 12:20 PM
I though you'd never ask. Check this thread out.
Oh you did all that? Never knew... interesting how the mods didnt help... and what? almost impeded learning performance... weird.
#235
#236
Well now that its learned and is fast in stock form put on the mods and see if you break 5.
#237
#238
I have updated the straight-line thread for your new and both sets of adjusted data. I think the penalties extracted for better than "standard" weather look right. Check out my effects of adustment post near the current end of the straight-line thread. Again, have a safe and good trip.
#239
My Ride: 2006 550i Sport Package, Cold Weather Package, Premium Sound Package, Comfort Access, Xenon Headlights, Adaptive Headlight Control, Navigation System, Steptronic Transmission. Silver Gray Metallic with Gray Leather. Added Red rear reflectors. Swapped stock Style 124 wheels and Bridgestone run-flat tires for BMW Style 125 5-Double Spoke wheels, 8" x 19" front, 9.5" x 19" rear with Michelin Pilot Sport PS2 tires, 245/40YR-19 front and 275/30YR-19 rear.
Originally Posted by Znod' post='246310' date='Feb 26 2006, 11:47 AM
There is an article in the current issue of Drag Racing on weather stations. It gives the same (essentially) standard conditions--60 F, 29.92 PSI; and 0% humidity. Do you know how to get humidity from temp, barometric pressure, and dew point?
#240
Thanks much E60VTA. I am trying to learn to do some weather calculations related to the weather "standard" mentioned above as well as to the method one of the auto mags uses in doing weather adjustments. But, doing these things is low priority right now.
